Thanks, I appreciate your support: it helps allay any fears that I won't be happy with the mill retrofit, when I actually get into doing it.
Can you elaborate a little bit on this new command called "INSPECT"?
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
