Need source for glue please! | | I need an adhesive which will cure in about 5 mins under UV light but that I can remove after machining the part it's going to hold.
I recal years ago using a reddish pink adhesive which was perfet- it cured under UV to a consistency similar to the mastic stuff you stick round your bath. It could easily be peeled off the component after machining.
Unfortunately I,ve lost the contact name. I even phoned up Loctite and they say they do it, but it's not available in the UK.
I have, honestly, searched for days for this. Any help greatly appreciated.
Thanks in advance.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
