Hi Dennis,
I downloaded the new demo version of SuperCam.... installed it (after removing the previous version, of course...) and I made a major step forward. The good news is that I successfully imported a drawing that originated as a PDF file... opened and exported through Adobe Illustrator! The bad news is that the file that I was able to open was the entire drawing, of about 60 separate parts. SuperCam told me that I had imported something like 10,600 graphic items.
And I'm not exactly sure what combination of settings I used to get the successful import. But most important, it tells me that what I am trying to do IS possible! I'll keep playing with it, and figure out which buttons to click to make the magic happen.
Meanwhile, I was playing with some DXF files that I downloaded from the CNCZone. They're the part drawings for building a JGRO CNC router. Unfortunately, the drawings all have little title blocks, lots of text, and other extraneous stuff. I know this is a dumb question, but how to do you erase, delete, or otherwise get rid of such things. I tried using the "Erase" command in SuperCam.... but it selected everything on the sheet. Using the "undo" command, one step at a time was kind of fun, as all of the drawing, title blocks, text, etc. came back... one step at a time, but that wasn't really what I wanted. Should I be trying to just select the actual drawing components, and cutting and pasting them into another document... or is there some other trick to deal with this?
Thanks!
-Taylor |
