Cruncher,
Thanks for your reply. The demo is not XP, so I assume that is why I didn't see .SAT files listed. Do you know if Autocad uses .SAT files as a standard, along with .DWG, or if that is an add on for them? Also are you using XP Professional, or XP Expert. I'm asking this to see if there is a posibility that XP Expert would have .SAT but possibly XP Professional would not have .SAT capability, because I'm thinking of purchasing XP Professional at this time. I also want to contact 2 new customers, one is using Pro E, & the other is using Solidworks. Do you know if .SAT or .IGES will work ok with those.
Thank you for your help. |
