Old 06-14-2004, 05:29 PM
rvan rvan is offline
rvan is on a distinguished road
Not All Lift gates are the same. There are trucks equiped with 5,000 Lbs liftgates.
I think your going to run int a problem with the flatbed angle with the ground. I am pretty sure its going to be way too steep of a grade to permit you to roll the jack off the bed onto the ground. The wheels of a pallet jack can only handle angles of a few degrees before the forks edges start digging into the ground.
If you can't find a truck with a heavy duty lift jack, consider renting a fork lift. Use the flatbed truck to deliver the fork lift and then load the BP on to the flat bed.
Good Luck!
