  #10
Old 11-21-2007, 08:26 PM
ger21's Avatar
ger21 ger21 is online now
Are you sure you have Mach3 setup correctly? Have you ever used Mach3 with the parallel port? Do you need some features that the G100 has that the parallel port does not? Because if you don't, just use the parallel port.
