Old 11-20-2007, 05:15 PM
kiltjim kiltjim is offline
kiltjim is on a distinguished road
Maybe I am misinterpreting.
If the switch is closed, the circuit latches (all the time, unless the switch is pressed). If I press the reset switch, it momentarily un-latches (machine could run), but then latches again. I tried simply changing the way that Mach3 sees the signal, but no good.
Am I doing something wrong?
