  #105   Ban this user!
Old 11-20-2007, 06:20 AM
Jimmy007 Jimmy007 is offline
Jimmy007 is on a distinguished road
Esmae I'm sure i have the 'ZHBDSPhandheldhost' program somewhere also, never loaded it. What does it do?
First Gcodes I ran were generated in Type3 and saved straight to the USB stick to run from the hand controller. Like you I generated different progs with file names as a tool change solution.
Not a garage or basement- stairs lead to a clean room upstairs where I do electronics assembly but its never clean cos I leave the door open so I can hear what the machine is up to ;-p
What lube are you using?
I found machine gun oil is the only thing i have found to date that sticks to the guides.
