If you simply drive the totem pole with a Flip flop set up to "toggle", you can do the same thing with a logic IC instead of with slow or uncontrolled enhancing rate transistors.
You can also do the same thing with an appriate fet driver as they make dual channel ones with "flip flop" capabilities so as NOT to have shoot rhru.
Fix the circuit design problem - not the symptoms.
Finally, even though 5v TTL IC's can drive fets, they DON'T do so well - not enough current to "hit the gates" to turn them on fast and hard.
GET A FET DRIVER!!!!!!!!!!!!!!!! |
