Thread: haas SL-40L
  #11   Ban this user!
Old 11-16-2007, 09:42 AM
Technical Ted Technical Ted is offline
Technical Ted is on a distinguished road
I'm 98% sure the tool setter came direct from Haas. There could be a small possibility that the distributor did a retrofit but I don't think so. I'll try to find out Monday.
If there's even a small chance of wanting to run anything over 500lbs (fixture+part) then I would contact Haas directly & inquire about weight limits.
You also need to make sure the turret can hold enough tools for the parts you want to machine. This is critical if you'll be getting the turret for live tooling or when working with large diameters.
