Old 06-09-2004, 05:28 PM
Bloy2004's Avatar
Bloy2004 Bloy2004 is offline
Fumbling Machinist
Bloy2004 is on a distinguished road
3 servo motors - What are the actual specs?
I just received these servo motors in the mail and since I have only one power supply(for my Shoptask 3in1)which has gecko320s, I interchanged the y axis motor with one of these and after tuning, the motor seems to run the axis without problem though maybe just a little slower.
I was wondering if I can do this safely(the motor didn't get warm) as these motors are rated at 30.3 volts whereas my power supply is 39 volts from Camtronics. If this works, then I can interchange the controller /drivers by only unpluging from one machine to use the other,while having separate configurations as is available in MACH2.
As long as I don't overload the motors, set limits on the geckos, and keep the rpms up, will there be harm inflicted on the system?
If these ARE 1800 rpm motors, what does that do to the other specifications as listed below in subsequent posts.
I'm feeling I made a good buy for the medium-weight(now that's relative) router that I am collecting parts for...is this true?
..or did I overpay?
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
Any responses welcome
