I am using thru the spindle coolant at 400psi and a walkasa carbide insert cutter at 1" 4 flute. I am told that the sfm 250 and chipload is .005". How does this relate to depth what depth would you guys run at. Do you adjust the rpm for different depth of cuts or just leave rpm alone.
I am cutting unhardened 420 stainless. |
