Kong: Thanks, I appreciate it. But I'm in Norway, so the postage will probably be more than the $17,50 I have to pay for a new PCI printer card locally. What I'm worried about is it may not be as good for outputs as an old ISA board, but the inputs should work fine. I'll probably try that and see if that leaves me with separate home switch inputs. The outputs should also work fine if I make a buffer board, but I was hoping I could avoid it.
Since neither of you mentioned any problem with the limit switches wired in parallel (NO switches) or series (NC switches), I assume that works fine? |
