Originally Posted by Mick40 I'm guessing to clean up the photo or drawing so it can be cleaner to draw a tool path?
I'm trying to learn as much as possilbe before I built a plasma cutter...So, what would the application to need this?
Thanks,
Mick |
Vector magic converts bitmaps to lines, so you can cut with it, whether it be laser, plotter, CNC router or plasma cutter. Their powerful computer does a much better job than the trace programs the come with Corel or Adobe Illustrator, so won't you have to spend so much time cleaning it up by manipulating the points and changing lines to curves or vice versa.
I've tried it with pretty good results but it's by no means perfect.
