Thread: Gantry
Old 11-09-2007, 10:55 AM
bearwen bearwen is offline
bearwen is on a distinguished road
Yes this is normal you will also notice that most DIY machines even welded ones and some of the Factory ones will do this even after you get the bottom on this is called racking if you search the forum you will find it ALOT the big thing is once you get the bottom on adjust the bearings for the snuggist fit that doesnt bind and then put a clamp or something in front of one side and push or pull the other side and see how much it racks this should be minimal also depends on what you mill and how deep you go in a single pass as to wether or not you will load it enough to rack it when your cutting.
good luck and have fun.
