Thread: Whaaaaa???
Old 06-07-2004, 03:52 PM
keithorr keithorr is offline
keithorr is on a distinguished road
Whaaaaa???
Rec'd a new IMS stepper today (3431-6.3) rated at 637 oz.in. to replace an obsolete 3424 rated at 235 oz.in.
So I'm reading the specs and fiddling with the motor turning the shaft (nothing is hooked up). Sometimes the shaft spins with only a slight detent feel, other times the shaft turns kinda stiff.
Then I notice the lead ends are sometimes touching, sometimes not, and if I short the two coil windings (A+ to A-, and B+ to B-) the shaft locks up solid.
I didn't get out pliers or anything to see how much force was needed, just using my fingers. Figure I might screw something up.
Anyways, what is going on inside that makes this happen?
