Mike,
That machine originally had a drain line (about 1" ) connected to a sheet metal collector near the back of the cylinder draw tube. The other end is routed to the hydralic tank. If the machine is somewhat level then oil leaking out of the cylinder will be returned to the hydralic tank. It was normal for these drain lines to get knocked out of place when moving the machine. Small leaks are normal, BIG leaks need to be fixed.
Rodman |
