Thread: G-REX wiring
  #11   Ban this user!
Old 11-06-2007, 12:02 AM
Lost Tourist Lost Tourist is offline
Lost Tourist is on a distinguished road
Brian,
I too am thinking about starting to wire things up but i'm a bit behind you as i still need to install the transformer.
If i understand you correctly your circuit should now look like the attached.
I assume you are using mach3 with the G100 plugin? If so did you have any trouble mapping the outputs from Mach3 to the G100?
