If you are using relays to reverse the actuator, you can also wire it using just two 3 pole relays, each would have two normally open to reverse the direction and a NC contact on each wired in series with each other connected across the armature will give you the dynamic braking.
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
