I meant on the J11 header, where can you get other sources of 5 volts, or do you need them? I want to make a parallel home switch setup, and then a series limit switch set up. I can use J11 for the home switch, and get the 5 volts and the ground from pin 1 and 10, but when I go to hook up the next set of switches, where do I get the 5 volts and the ground? And where do I hook up these wires? I can follow the pins used on the pdf for the first set of switches, but for a second set, which pins do I use and how do I get the voltage. Hopefully that made sense.
Also, how do I set the step pulse to Active high in TurboCNC?
Thanks.
