So, I don't have to worry about anything on the Active high or active low, I rememver something in the xylotex pdf about how the setting have to be a certain way for the motors to run?
2) What is the sleep and enable? ENAX?
3) So am I missing anything for setting this up, this is what I think I need for getting up and running:
a) Change the Vref untill 2.088 or something like that.
b) Plug the motor wires in A, A#, B, B# for each Axis.
c) Plug in the VCC cable, and the fan
d) Plug in the Power Supply wires
e) Plug in the Parallel port plug in
f) Run stepper test program
4) I have heard of a lot of people running their motors at a higher voltage than specified. How exactly do I do this? Do I have to lower the amps? What about the Vref?
5) If I have multiple limit and home switches, I saw that the board has only one +5 Volt and Ground terminal for external switches ( I think), where can I get the ground and 5 volts from for the extra switches? Do you know what I mean?
Thank you so much for your help.
I really appreciate it. |
