Thread: Wiring Motors
Old 06-06-2004, 04:38 PM
ger21's Avatar
ger21 ger21 is online now
I have 8 wire PacSci motors, and the wiring diagram in their spec sheets is the same as yours. Basically, you have 2 pairs of coils. 1 pair on the side of the diagram, and 1 pair on the bottom. To wire them in series, you just connect the end of 1 to the start of the other.
You don't have to do anything for the sleep or enable, it should be ready to run the way you got it. I believe active high means it steps when it gets voltage, active low means it steps when the voltage is off.
