Old 11-05-2007, 03:39 PM
Tony Mac Tony Mac is offline
Tony Mac is on a distinguished road
Hi Jason,
Interesting part that on the surface looks like an easy 2D project but the round location features on the front plus the lug on the top surface turn it into a more challenging piece. If the component needs t obe machined from a solid piece of material then it will need some pretty advanced CAM software. If the component can be profiled and maybe the top lug added as a separate piece then the 2D machining options in most 2D machining software will do the job.
If you have the DXF for the plan view of the component we can send you the GCode to test the machine etc. and I would expect this type of shape to take only a few minutes to cut out.
I hope this helps,
Tony
