Old 11-05-2007, 02:40 PM
Mike@Torchmate Mike@Torchmate is offline
Mike@Torchmate is on a distinguished road
Originally Posted by LenMcC View Post
yeah, i figured we would have to set a minimum plunge so the machine doesn't think the material dropped away. you don't see perforated sheet as a problem, though, right mike? i know i talked to someone (probably not at torchmate) that said perforated is no problem. i may have seen a video of a plasma table cutting perforated, too, but maybe not...
We have cut perforated material a lot here in the shop. There are a few conditions though. It has to be done in manual mode, otherwise when the cutting arc moves from pilot to transfer arc the voltage reading will change dramatically causing the height control to respond. The second is that the plasma cutter has to be in the Perforated material cutting mode in order to maintain the pilot arc across the gap and as soon as it senses the material it activates the cutting arc again. The last is the cutting speed, if it's too fast the arc may not transfer in time to sever the material.
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
