Hi all, I am having some trouble about knowing which wire for my motor goes where. I'm not sure.
1) I have an 8 wire Vexta Oriental Motor Model Number PH2610-E2.9B. You can find the specs for it here :
http://www.electrotec.us/Portals/4a2...610%20Spec.jpg
and if you look down at the bottom of the page, there is the wiring for each colour of wire for the motor. I want to wire the motor in Bipolar Series for the Xylotex driver.
My problem is, I don't know which colour of wire goes where into the xylotex. Which pin, or does it matter as long as four wires are plugged in? Which wire is B, B# or A, A#?
2) Also, what does it mean by some of the settings have to pulled to active high or something has to be pulled, I don't understand.
Thanks.
