Originally Posted by mitchDM It is certainly a plan as i'm not too good as working with metal, is there anyone else who thinks the MDF machine wouldn't be suitable for cutting steel? |
For one, cutting steel requires lots of coolant, which doesn't mix well with MDF. And second, while it's a decent machine for light work, most who build the JGRO find that is flexes too much, and eventually build another machine. If you'll only be cutting steel, you might want to look at building a plasma cutter.
