Old 11-03-2007, 12:10 AM
ssbender ssbender is offline
ssbender is on a distinguished road
Originally Posted by Geof View Post
The picture is a bit fuzzy but it shows a little tool I picked up in a hardware store years ago. You screw it down to a block of wood pot your rod in one of the grooves and do your bend. There is a hole pattern to put in 1/4" dowel pins for tight little bends but I have lost some of the pins.
The bottom line is that you do not need anything complicated to make quite complex bends. A notch in a piece of metal or hardwood will work along with a length of tube to put over the wire or bar you are bending. Do some experimenting and see what works; experience is the best teacher sometimes
that was extreamly helpful to me... can you provide me with the tools name or perhaps a company who makes it. This way I can go out and buy the contraption. thank you!
