Old 06-04-2004, 04:21 PM
Neal's Avatar
Neal Neal is offline
Neal is on a distinguished road
Edster--
The VH-65 will operate as a true fourth axis. You'll need the wiring harness, if it's not pre-wired, amplifier, controller card, and wiring and plug from the cabinet up to the bulkhead. The parameters in SETP will need to be set to XYZA axes, 90:1 axis ratio, and M60/A axis brake set to Yes.
The rest is in the programming. Remember that rotary axis feed rates are stated in decimal degrees per minute.
Neal
