Need a Technique to Set the Z Axis to Zero | | I have several routers running and decided to try a lathe. It's almost done. Need help with a technique to calibrate the tool tip to the center of the spindle. I'm using Mach 3 Lathe.
This is probably a simple/stupid question, but I'm out here operating in a bubble.
Thanks in advance. |
