Gpena
Here is the cable info, your cable looks ok be sure to set the PC dnc software to "software handshaking"
Hurco round connector 25 pin serial
pin B recieve data ----------pin 2 transmit data
pin C transmit data----------pin 3 recieve data
pin F signal ground----------pin 7 signal ground
Hurco round connector 9 pin serial
pin B recieve data ----------pin 3 transmit data
pin C transmit data----------pin 2 recieve data
pin F signal ground----------pin 5 signal ground
Set dnc for SOFTWARE handshaking
good luck
Rick |
