Thread: cmm software
Old 05-20-2003, 01:06 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Originally posted by Dan B
If you buy a Faro or Microscribe arm, Rhino can be used as your software. I've never done it, so that's about all I can tell you about it.
Dan
Hey Dan, a Faro arm is worth as much as a second hand mill!
I'm still uncertain as to whether the Microsribe would be adequate, having had no experience with the resultant output.
I like the idea of using a mill to probe the part, since even a wobbly old mill will give much superior results compared to a Microscribe. I also like the idea of letting the thing do the probe routine all by itself.
Thanks, WMS, I'll check out that link you posted, too.
