  #12   Ban this user!
Old 10-28-2007, 03:14 PM
neilw20's Avatar
neilw20 neilw20 is offline
neilw20 is on a distinguished road
Thumbs up Some FETS ok at low voltage.
Originally Posted by NC Cams View Post
It depends on how much power you're swithing and whether you're switching a fet or a NPN or PNP transistor, as in where you place the 5804 versus the 7414.
Depending on how much drive you need, that would determine what sequence I'd put the chips. Afterall, the 7414 is only inverting and squaring up the signal logic so it can be rather forgiving where it is placed. I"d be inclined to have the 7414 properly trigger an adequate driver as opposed to driving a transistor directly, espcially if you're looking for speed.
Driving a fet with only 5v will not switch it on fast or hard enough. Will it work? Yes. Will it work better/cooler with a proper driver? Yes.
Ther are some MOSFETS that only need 5v on the gate.
Check out manufacurers Master Selection Guides.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
