Originally Posted by ger21 I used that to build a vacuum veneer press. You'll need to build a reservoir for it, and it's quite noisy. Check out www.joewoodworker.com for plans to build a complete unit.
And yes, it should work. |
do u still need a mac value if u use your compressor for your line in?
I looking for info on how many inches of Hg do u need to
hold some down for a cnc cutting ie 4x4 sheet of plywood?
