Old 10-24-2007, 07:14 PM
Geof Geof is offline
Use a castellated nut and put a split pin through a hole in the bolt.
If the bolt and nut is big enough put a diametral saw cut 3/4 of the way through the nut then drill and tap for a small bolt to pinch this cut and lock the nut against the threads.
