You ask and it shall be delivered...
Alt-F for the file menu, arrow down to "Create or Edit G Code File"
Now in the editor... Alt F for the File pull down menu, down arrow to open... you now have a DOS file/directory screen
Use the tab key to switch between windows and now you can load files from anyware on your system.
Alt-f to save the file to cncpro\gcode from the editor.
NOTE: to be able to load the gcode file into CNCPro it must have been saved with a .txt extension and direct disk access must be enabled in the cncpro.exe properties
regards Gary
__________________ embrace enthusiasm to accomplish the task
Gary Davies... www.durhamrobotics.com |
