I just got the Xylotex driver, i need to limit the curent going to the motor. 1.7amp is required for the motor |
Then you will need to put a resistor in series with the motor. You will need to know the voltage of your power supply, and the resistance of your motor, to work out what size resistor you will need. Its been a while since I have done this sort of calculation (its an easy calculation from memory) but if you post both those numbers I am sure someone here can tell you what size resistor you need.
