Old 10-22-2007, 02:39 PM
Brakeman Bob Brakeman Bob is offline
Brakeman Bob is on a distinguished road
Originally Posted by Mastercam User View Post
An example of when I would want to use this function would be when I am handed an $80 coolant through drill and I need to make changes to 30 operations. Those 30 operations are now using a regular twist drill and a G83 deep hole drilling cycle with a low feed rate. Now I wish to use a G81 cycle with a faster feed rate and the proper M code to turn on and off the high pressure coolant. No doubt I could think of hundreds of other situations if I really though about it. I prefer editing a spreadsheet to trying to use Mastercams Edit Common Parameter approach. A spreadsheet is faster and more direct in this situation.
Is this a one-time situation or something that that will be rolled out out over a multitude of jobs. If it is the latter and something that widespread in the shop, then I would edit the GPP file of the post to substitute the G83 call, the feedrate and add the thro' coolant codes. For the former, well, this approach works but you could end up with lots of different versions of the post - not a good idea.
