The Citizen Cav is very easy to work with. They have integrated it very well with the control. It does NOT have it's own control it works from the machines control. The pusher is actually another axis for the machine and you can read it's position as you can with the X,Y,Z,C axis'. Simple change overs, better support closer to the end of the bar. The oil that you use in it can be the same oil you are using as cutting oil, that way you will never get any cross contamination. They reccomend oil but there are a few case in which people are cutting with coolant and using coolant in the Cav also. |
