Originally Posted by Tayloned Aaron's Stepper motor programmable driver boards kits arrived and have now been assembled. Plus an enclosure of own design has been constructed to house 3 of these boards. The aluminium plates used also act as an extended heatsinks for the driver chips used. Photos attached...
Also can provide technical drawings of parts, if anyone is interested... |
That's a very robust enclosure, and well made. Nice job on the design.
Edit: I just noticed that the small on-board heat sink is 90 degrees to the flow of air. Could you rotate the boards so that the heat sink is in line with the flow of air for less air restriction?
CarveOne
