  #11   Ban this user!
Old 10-20-2007, 06:02 PM
Don Clement's Avatar
Don Clement Don Clement is online now
Don Clement is on a distinguished road
Hi Mike,
I just installed SprutCam 2007 and am trying to mill an 11.86” diameter curve in a circular part held in a 3” internal expanding 5C collet held in the same EagleRock 5C fixture on my Tormach. The mill is a ½” diameter solid carbide ball end mill. As shown in the following photo there is a problem on the flat area in the center of the part whereas the outer edges are quite smooth. I originally created the G-code using SprutCam 4 and a waterline. I am now redoing this program using SprutCam 2007 and waterline but am still figuring out the new “fixtures” in SprutCam2007 vs “restrictions” in SprutCam 4. I believe if I check scallop height instead of using a fixed distance in the milling strategy that the rough areas in the middle will smooth out. I need to figure out the way “fixture” restrictions works in SprutCam2007 though. Any help with how to use” Fixture” and “restrictions” in Sprut2007 would be appreciated.
http://i72.photobucket.com/albums/i1...inDiaCurve.jpg
Don Clement
Running Springs, California
