Dry Run,
You can also cut a 'Higbee' thread on a lathe without live tooling. Cut the thread as you normally do and then recut it with a 'cut grip' or some sort of square tool untill the first thread is cut off and is blunt. make sure the rapid is set at 100% so the 'ramp' is steep. You can adjust the z start to line up the edge of the square tool with the root of the thread. Here is an example of one that we do in a puma lathe.
Hope this helps.
JK
Here is a snapshot of what you should end up with...
G20G40G80G97G99
T0202(SER 0750 K16)
(INSERT 16ER 11.5 NPT)
G0X-1.95M3S800
Z.3M8
G76P010060Q0150R0040
G76X-1.75Z-0.595P0695Q0100F.0869
G0Z0.5
G28W0
M1
G20G40G80G97G99
T0303(GHDR 19-3)
(INSERT GIP 3.00E-0.20)
G0X-1.95M3S60
Z.15M8
G76P010060Q0150R0050
G76X-1.75Z-0.138P0695Q0600F.0869
G0X-1.790Z-0.060S2000
G1X-1.695Z-0.013F0.005
X-1.400
G0Z.2M9
G28W0M5
M30
