Originally posted by HuFlungDung
I also have the notion that a machine controller running in windows may have inherent handicaps that will never be overcome, due to the way the OS works. The more advanced the OS, the less hardware control you have. |
HU, There some exceptions to this, Siemens, Fanuc, Mitsubishi,Cincinnati all have PC based controllers working fine under NT. There is another one coming out shortly that is aimed at the retro-fit market, I will be using an initial version hopefully in an upcoming retrofit and will post the results, it look very promising at this point.
Al
