Old 10-17-2007, 09:38 AM
5th-axis 5th-axis is offline
5th-axis is on a distinguished road
Fagor 8055i Mill control Problems
We have a Fagor 8055i control retrofit on a Clausing knee mill. When we program it, the X-axis is always mirror imaged. For example, If I program a part in the 1st quadrant, the tool always moves to the second quadrant in X.
It is almost as if the encoder or something is wired wrong or a parameter needs changing. Anybody have any experiance with this?
I have tried G10 mirror image cancel at the beginning of the program and that does not alleviate the issue. Fagor, so far, has been no help at all. They say the axis movement is correct. The table position is moving negative and the CRT confirms this. What they do not seem to understand is that when the table moves negative, my tool position is positive of my zero. So when my program runs, it reads my positive moves and the tool is negative of my zero and engraving air. I hope this is not to confusing. I have given myself a headache.
I am using Surfcam to program. The program will run on my Fadal with the Numatix control perfectly. It is just a simple engraving program.
Any help is most certainly appreciated.
