Originally Posted by 2_jammer Hello Bear,
I'm running a desktop PC using the rs-232 9 pin serial port to the CNC's 25 pin connector. The controller is a Meldas 520 on a Mighty/Viper VMC.
I've tried a null modem cable and had the controller outputing, but the PC wasn't receiving the data. When I tried to use a 3-wire cable I get a E04 Device not ready error. I'm going to build another cable and try that. I'm attempting to use two different DNC programs: Quick Link 2K from MicroCimm, and NCnet Lite 4.1. What kind of issues are you having, and what type of set up are you using? Shane.
P.S. Thanks for the info Al, I'll look into that. |
Hi, Have you solved this problem? I'm having the same problem
