You can also go to the group site under files and get the R325-Art.zip file and you can have variable homing speed as well as selective axis homing! The feedrate is maxed at 4 as this is the fastest my system would take without faulting out when the home switch tripped out. You also have the option to use the limit switch as the home switch.
In the case of a mill/drill such as mine, this also does not reduce the already limited travel. I also fly in the face of convention on the Z axis and home it down. With a "portable" home switch, I can tell turbo to home to a specific distance if desired. This is my poor mans tool offset as each tool can now be set to an accurate reference point when the tool is installed.
__________________ Art
AKA Country Bubba (Older Than Dirt) |
