For the outer surface, I'd be fine with fillets. That is to say that the inside corners need not be a sharp right angle. 1/8 or 1/4 would not be unreasonable.
In fact, I think the parts would look better that way. I just didn't add fillets into the models because I didn't want folks to think I have a specific radius in mind.
I really would like the outer edges to be radiused to take the sharp edges off. Again 1/8 or 1/4" would look nice. But, I am concerned enough about cost that I would drop this idea if it means adding substantially to the cost.
That is why I provided versions of each model with and without radiused edges.
Now, regarding tolerance, I need the bores to be precise. If I slide a pin or a beam through the openings in the collar, for example, I want that pin or beam to fit with almost no perceptible play. I'm using DOM pins and beams.
I would imagine 0.001 would do the trick, but this isn't my area of expertise. What tolerance would you recommend if my goal is for the parts to slip together, but have almost no play at the joint?
Originally Posted by jjasshipley how big of a radius is acceptable for the inside corners? what kind of tolerances? |
