use the front tool post for turning and use the rear tool post for cutoff. this way all you have to do is program an x feed for the cutoff and locate its position in the z.
that way all of your standard coding works, except cut off will be in reverse. some also say that the rear cut off tool post is better on these small lathes as there is less chance to suck the tool under the material. |
