When I tried the 8020 aluminum bearings I had to use two of them since they are sloppy parallel to the bearing face (like a lazy susan). If you use 2 bearings 90 degrees off ( say one on top and the other facing out) and tie them together they are very tight until they wear too much. I'm still using the first set but I don't do much work (almost none) on the router. |
