Old 10-09-2007, 06:41 PM
jason3791 jason3791 is offline
jason3791 is on a distinguished road
It is most likely the Z Axis driver board. Mine did the same thing. If you follow the Z axis cables into the lower part of the controller box you will see it connects to a board down there. It is two boards sandwiched together. The connection between the two boards on mine was bad. I resoldered the connections on both boards and had no more problems. Hope this helps.
