Ben
Sounds like handwheel logic problems. Take a look in the inputio.fil file. Also run a log file. Try to trace the logic. I bet that that particular operation or feature you select modifes some rapidspeed settings or turns something off that does not get reset back. Send your cbk file and a logfile and as much detail as you can into camsoft tech support. I bet you they can help.
Smith |
